Edelbrock discontinuing TPI Intake Base 3861
AussieCorvetteNut
Gold Coast Australia
1984 Two-tone Blue Coupe
Hi everyone,
I emailed one of the speed shops in Australia today to enquire about purchasing an Edelbrock High Flow TPI Intake Base (3861) and they said that Edelbrock had discontinued them...WTF?:mad
I then did a quick search online, Summit was out of stock with a big discontinued banner, but Jegs had 9 in stock.
Well they have 8 in stock now...
Looks like due to supply and demand, the parts for TPI's will dry up.
I am retro fitting a TPI unit to my 84, with a good set of heads, roller cam and lifters (Comp Cams 12-467-8). Am also looking at the FAST EFI Management system to run the TPI, self tuning no need for a laptop and no need for changing chips if I change the set up.
Also no need to run a 30 year old harness and ECM.
I managed to get a used TPI without ECM and harness and it is on its way across the Pacific Ocean, also picked up some Edelbrock runners and now the intake.
If your after one of these intakes, best act now.
...maybe 3817
Looks like the Vortec intake 3817 is available.
Can I bolt Vortec Heads to my Gen 1 block.
I am trying to fit a TPI unit with EZ EFI 2.0 ECM and harness, to my 84.
Yes- Vortec heads will fit your engine, provided you use a Vortec specific TPI base like the one you mentioned above.
However, there is a limit on the lift for the cam though. I think Jegs and Summit specify the lift limit as .475".
...I was hoping on retro fitting a roller cam
Thanks Kane.
Good and bad news, as I was hoping to fit a retro roller cam from comp cams and run 1.6:1 roller rockers.
The cam is a retro fit EFI - 12-467-8 or slightly smaller 12-466-8
My 88 Corvette TPI is currently working its way through TN, on its way to Australia.
I also have a set of Edelbrock Runners coming from Western Australia, with limited use on them.
The baseplate was the only other key piece.
Tony
No, I received an email from Jegs...sorry but the intake you have ordered has been discontinued by Edelbrock. We apologise for any inconvenience...
:mad:mad:mad:mad:mad:mad
Check Ebay. Looks like they have some Vortec TPI bases available. :thumb
3817 Hi-Flo TPI Vortec Intake Manifold
Edelbrock 3817 Hi Flo TPI Vortec Intake Manifold | eBay
If it were me... I'd consider using the Pro-Flo intake, fuel rails, and throttle body instead.
With a cam that has a 2k-6k rpm range like the one with the part number you listed above, well... stock TPI runs out of breath at about 4,800rpm or so. Even with a ported base and runners, I think it will struggle with a 6k rpm peak. TPI is designed for low end torque with a long runner system.
Just food for thought...
One more go at it...
Hi Kane,
Thanks for the tips.
Jegs cancelled the order and refunded, but they had kit 3892 which I know has been discontinued as well, but they still have it listed.
I ordered one, but I am expecting that they will cancel this order too.
I am after something with that mid 400 ft/lbs of torque at the flywheel, thats why I was heading down the TPI path, wasn't too concerned about high rpms.
I contacted FIRST TPI and they are planning production in the spring as their shop is being renovated.
If Jegs cancels the order, then I might just sell on the parts I have and look into the Pro -Flo.
My only concern is bonnet clearance, the Edelbrock website is saying 9" at A, which is the front section I think.
84 bonnets are low, but as long as it is around the TPI height, I will have not problem as I know the FIRST TPI fits without bonnet changes.
Thanks for your help, I will do some research on the PRO FLO XT today.
I am still keen on using the EZ EFI system, so I need to check out if the Multiport kit 30404 will run the PRO FLO.
Tony
