topless82vette
- Joined
- Nov 1, 2001
- Messages
- 910
- Location
- southern california
- Corvette
- 1982 convertible (not factory) stock 350cfi auto
I just finshed this setup. Its in very nice shape, it's a edelbrock 3860 manifold with slp runners. The system is for 1990-1991 speed density cars. For it to work on a corvette all you will need is your fuel rails currently they have f-body fuel rails on it.
the plenum has been ported and cut for a monoblade throttlebody. The runners are first design meaning the front two runners on both sides are completely siamesed and the rear two on each side are semi-siamesed. It looks like everything has been gasket matched on the intake manifold.
You could easily port this system much more. It does have provisions for both styles of egr feed, either from the heads or through the corvettes exhuast manifold tube and the manifold is factory drilled to fit early style heads or later style heads that have the center bolts going in almost vertically.
The back sides of the runner were not polished and still have powder coat remains on them .... system does have various knicks and could use more work to be perfect but as it is it looks very nice.
900.00 + shipping charges for the setup sorry thats as low as I can go on this. Serious buyers only please.
system will need the following
fuel injectors
fuel line O-rings
throttle body
bolt kit
gaskets.
here is a picture of everything. Tomorrow I will put it together and take a picture of it as well.
fuel injectors
fuel line O-rings
throttle body
bolt kit
gaskets.
