Electric Cooling Fan Direction
edevince
Michigan
1969 LeMans Blue Coupe
Hi guys
For a elec cooling fan mounted in front of radiator, which is correct direction for it to turn? (When looking from front of car)
Thanks!
Ernie
I would say. At the front of the radiator it should push it through the radiator. So if looking at the front of the car if the upper fanblade is at the right closer to the radiator and further from the radiator at the left then the fan should turn toward the passengers side. So pushing the air toward the radiator. Looking at some youtube vid's should help :)
Greetings Peter
Hi guys
Thanks!
Ernie
It could turn either way depending on the fan blades. It needs to pull (or push depending on how you look at it) air from the front of the vehicle towards the engine. Hot wire the cooling fan before installing to make sure you have the right set up.
