good idea gettin rid of the flex fan, however, I am no expert but you may be short of air with just 2000 cfm unless you have a much better than stock radiator to transfer the heat more efficiently. I am about 400 hp and my fan and full shroud still lets it get up to about 210 sometimes. Mine is stock radiator and fan is a puller (mounted between engine and radiator). I don't believe distance from the radiator surface is as important as completely sealing the radiator to whatever shroud, making the fan or fans pull air through the entire radiator. Make sure your air dam underneath the radiator is in good shape, as this is what brings air up to the front of the radiator at cruising speeds. Looks like Norval there is both pushing and pulling air to coo his monster.
