Electric pump conversion signal wire?
LT4
Las Vegas
1996 Polo Green LT4 6 Speed
1996 LT-4
There are a million ways to skin this cat, but what have you guys used to turn the water pump relay on? Id like to avoid fishing all the way into the dash. What is keyed hot under the hood and close the the battery? Just run a scotch lock? Wondering everyone's choices before I take the plunge. Ive just been pulling the fuse on the Mezziere OEM wireing but thats getting old after 2 days! lol
1996 LT-4
Holy hell, absolutely no scotch locks. Ever.
You should use a 30A rated relay to power your water pump. Solder and heat shrink all wire connectors or use quality tape and pull it tight.
Do not cut corners on wiring.
