Jeff Farrar
I currently have a Holley "blue" electric fuel pump mounted in the rear right below the gas tank. There is no fuel pressure regulator inline. This setup has been running the car for about 15 years. I assume it has been working okay buy I have only had the car for a year. The engine is a 454 with a Holley Street Avenger 670 that requires only 5-6psi. I have it all apart (just replaced the gas tank and sending unit) and am unable to check to see what "real" pressure is being supplied by the pump.
Questions:
Is there any reason to keep the electric pump? If I need to shell out the $$ for a fuel pressure regulator why not just go back to a mechanical pump?
If I keep the electric pump, can I mount the regulator directly after the pump? I would like to not mount it near the carburetor.
Thanks!
Questions:
Thanks!
