Paul Douglas
The "daylight running lights/turn signal" on the right front of my 2002 Coupe worked fine for 3 1/2 years and then the right one burned out. Thought no big deal. Went to the parts house and got the correct Sylvania bulb. When I installed it, I found that the original bulb had a hole broken in the nose of it.
New bulb worked for one month, then it went out. It had a hole in the front also.
Replaced it, and it lasted two weeks. When I replaced this one, I wore surgical gloves, used dielectric grease in the socket, and it lasted a week, same type of hole.
I have noticed that the light tan socket/connector is slightly burned (or overheated) looking. My Chevrolet dealer has no idea what could be causing this problem. Was suggested by them that I drive it too much, which makes the light stay on too long, and it burns out.
I know there has to be a simple answer that one of you techy people will know. I need help. Thanks.
