L
ltmark
I am fighting an electrical problem on my '85. It was running poorly all of a sudden and diagnosis revealed it was the Burn Off Module. However, when I tried to start it a second time to verify that was the problem per the manual troubleshooting guide, it now clicks the starter solenoid briefly and then all power is lost. If I remove the positive and let it sit for about 5 minutes and then hook it back up, the same thing happens...I have 12 volts, interior lights, etc., until I try to start it and then everything goes completely out! If I do a voltage check at the battery, it shows about 1.4 volts....as soon as I remove the postive cable, the battery itself shows 12.5 volts again?
