- Moderator
- #1
bill81vette
Moderator
Over the course of the winter I removed and installed my starter,right side exhaust manifold,ignition shield,and replaced the upper bearings in my steering column.I finally finished it Sunday (hoping I could take it out for a quick spin on such a nice day),got it started up and my power windows,and my blower motor for the heater doesn't work....:ugh everything else is working perfectly!!!!
So,I start checking and double checking all my connections.checking feeds as well as grounds.that I have unplugged and plugged.I have no power to those to circuits on the fuse panel and I cant figure out where the feed comes from???? could I have messed something up in the steering column and not know it??? I have looked with a mirror several times to see if I moved or done something up above the steering that I shouldn't and everything looks like it is where it belongs and plugged in....
any other suggestions would be appreciated!!!!
Thanks,Bill
Thanks,Bill
Bill,
) I'll check further next chance I get!!
