The lights went out on the dash of my 87 Vette. I was still able to see the readings. I tapped the dash and the lights came back on. This happened 3 times so far. Loose connection? Bad bulbs?
The connector between the two boards inside the cluster is a common cause of this problem...either due to a solder joint that has broken loose or a faulty connector terminal.
I have had mine apart many times. THe time that mine went dark (I could hit it and make it light up) the solder joints were broken on the pins that connect the two boards. It is a very simple soldering repair.
