chevyman1759
Hi! I have a question about an electrical part.Hopefully someone can help me.I have a 1972 coupe and had to remove the steering column to do a repair.After un-hooking all the wires I noticed a wire was hanging lose.I traced it done to a capacitor mounted on the ignition switch.I can not fix it because the wire is broken off inside which I can't get to.Can anyone out there tell me if this part is important?The part # is 801249 with the letters DR in the middle and .5 MF at the bottom.Will any one-wire capacitor with .5 MF work or do I need the original part?Thanks for any help you can give me! Ron,
