P
purpleRac3r
Many thanks to those who have offered suggestions for tracking the miss I experienced. I have performed most of the tests suggested and added a couple members of Boone Trail Corvette Club mentioned. I fear the heart has stopped beating. :cry The miss indicated in my previous thread advanced to engine ticking, then quickly to barely run at all with pedal mashed to floor. A compression check results in 55-85 lbs. in 5 of 8 cylinders (I'm told they should be around 125 to 140 lbs.), and a whopping zero in the remaining 3. Yes, that is definately no compression whatsoever. I triple checked each cylinder, and the gage itself. The three zeros were consistantly the same cylinders. Strangely, no oil in antifreeze and vice versa. Also no loud bangs one would expect to hear with catastrophic failures. <sigh> ;squint: I'm now looking at a new motor. My total engine replacement budget will be around $2000; I'm considering the GM Goodwrench 290hp/326ft-lbs 350cid crate motor (Jeg's part number 809-12499529) with the Edelbrock Performer manifold I just put on the fried motor in the spring and a freshly rebuilt Quadrajet matched to the intake. This seems to be the best bang for my bucks at the moment. However, I am open to suggestions....
