Emblem Question
Cowtown Dave
Cowtown, Texas
65 Convertible 327 4 sp white/blue
I have a 65 327 250hp vert that has no front fender emblems? I have seen some 65's with emblems and some without. What is correct?
'65 should have emblems, the only midyear without is '67. Are the holes still there? you might want to look inside to see if just the outside was filled if not, or maybee the fenders were changed.
Tom
Okay no holes on the inside of the fender, I guess there is a new front end on this?? Can someone please give me some measurements so I know where to place them or lead me to the right resource.
I believe if you check in tha Assembly Manual, there is a section that has the measurements for placement.. You might try doing a search through the archives here.
Tom
