Ok, Guys I got back from the test and I passed with flying colors. The new additions were
.073 jets replaced by .071
Rods stayed the same at .046
Leaned the mix to bearly running at idle , fine when warm
same 180 temp thermostate ( the TVS's work @ 165)
Linked the canister vacumn into the PCV (vacumn for sure)
Here are the first results
The readouts from the last test are as follows: 15mph test, 1346 rpm, CO2%- 11.0, O2%- 3.7, HC(ppm) MAX- 194, AVE- 57, MEASured- 193, CO(%) MAX- 1.26, AVE- 0.25, MEAS- 1.88, NO(ppm) MAX- 1286, AVE- 570, MEAS- 64 (FailedCO%) 25mph test, 1365 rpm, CO2%- 10.6, O2%- 4.0, HC(ppm) MAX- 161, AVE- 45, MEASured- 176, CO(%) MAX- 1.06, AVE- 0.19, MEAS- 2.21, NO(ppm) MAX- 1146, AVE- 648, MEAS- 36 (Failed HC and CO%)
Here are the final results:
15mph test, 1694 rpm, CO2%- 10.2, O2%- 6.5, HC(ppm) MAX- 194, AVE- 57, MEASured- 49, CO(%) MAX- 1.26, AVE- 0.25, MEAS- 0.00, NO(ppm) MAX- 1286, AVE- 570, MEAS- 570
25mph test, 1672 rpm, CO2%- 10.0, O2%- 6.8, HC(ppm) MAX- 161, AVE- 45, MEASured- 29, CO(%) MAX- 1.06, AVE- 0.19, MEAS- 0.00, NO(ppm) MAX- 1146, AVE- 648, MEAS- 648
As you can see CO@ at 0.00 HC, down considerably, and NO wet up to just below the average.....I learned way more than I wanted to about Emissions than I wanted but it's done and I can move on to the Fun Stuff.....Front End rebuild next Thanlks again for all the help hopefully this thread will help others get through the dreaded CA emissions
