MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
With quite a bit of help from Brian (AKRAY4PLAY), I've gotten some of the basics of my new engine sorted out.
So far, I'm looking at a 400 block, bored 30-over. That gives me 406 cubes. With 5.7 rods, 64cc Trick Flow heads, and 18cc dish Keith Black pistons (0.010 in the hole), that's just shy of 10:1 compression, depending on the exact thickness of the head gasket.
That's the basic stuff, and the most "scientific." Now comes the "art" side of engine building: I need to get the air in, get the valves moving, and get the plugs firing.
In reverse order:
Can I use my stock ignition? Or do I need something fancier?
Anyone have any cam recommendations? I was browsing catalogs, and the Comp Cams XE262H or XE268H look sort of like what's been recommended to me (by Brian and others), but I'm not exactly a cam expert, by any stretch of the imagination, so any advice would be appreciated. I'm looking for torque, of course
What sort of intakes should I be looking at? Hood clearance seems to be an issue (and I'm not replacing my hood), so any insight from people who know what will fit would help out greatly.
Joe
In reverse order:
Joe
