I'm looking for some suggestions on how to get the engine and the area around it cleaned up and detailed. Where do I start and what are the steps to getting it to where it is presentable? I don't have a show car by any means and I'm not looking to get the engine there either. I just want it to be clean and how do I keep it that way and still drive it?
When I bought my 86, the engine & compartment were filthy. My engine needed a tune up and a new serpentine belt. I pulled the battery & alternator,when removing the belt I removed the brackets for the altenator, took off the basiclly every thing on the front of the engine. I cleaned all the brackets and painted them, I taped up the alternator and painted it.
I bought some degreaser (bio degradeable) and cleaned the engine, with all
the brackets off I was able to get the hard to access area around the front pulley. I used gunk the area inside the compartment. I rinsed it down.
My valve covers leaked oil so I bought VC gaskets and removed the covers, I must admit this was a pain in the a-- ! the paint was all chipped so I stripped them down, primed & a coat of rinkle paint, looked like factory.With the VC off I directed gunk onto the intake manifold & used an old golf shoe brush and and rag and cleaned the area around & under the fuel rails. All the rusted brakets I degreased wire brushed & painted. I put everything back together,
new wires. (started looking real good). the fan shroud & air intake hose i cleaned with gunk and a rag and a brush, oh I also replaced the radiator hoses when I had all the brackets off, also I raised the front of the car and pulled the front wheels. Using the bio-degreaser cleaner I cleaned the front end, and under the front of the engine, the oil pan and the transmission.
After everything was back together and running I gave the engine, compartment and firewall another shot of gunk, rinsed it down let it dry
and got out the WD 40, I sprayed everything in the engine compartment a real good coating, even the headlight motors. Dont forget under the hood!
I spray the gunk on it and wipe it down. Net result, it looks great, you will need to give the engine a repeat drenching of WD 40, and it will stay shiny for quite awhile, you will also find all the oil leaks. a good saturday & sunday project. Now strip the ugly plastic coating off your wheels and see them come bsck to life!
tOM
