engine code help
Bioscache2
Upper Marlboro, MD
2001 Blk Coupe
I got the check engine light and got the code P0442. I checked the code list and it doesn't exist. The closet one is P0441 EVAP System No Flow During Purge but the list was for 2000 and I have a 2001. Is what I wrote a valid code or did I just see it wrong?. Also if I saw it wrong what does the other code mean? Thanks.
Quote from C4/C5 Specialist"
Hi there,
The P0442 is for a small leak detected in the Evaporative emissions system within the car. This could be caused by a slightly loose gas cap, or refuelling while the engine is running. That is what set your light this time.
I would suggest to reevalute the condition if the light comes on again.
Allthebest, c4c5
Original thread.
http://www.corvetteactioncenter.com/forums/showthread.php?t=43061&highlight=p0442
Thanks, Pete! :)
-Patrick
yea I appreciate the quick response, thanks
