Engine Dress Up
RLE80L48
Central Pa.
1980 Black L82
OK, I have collected most of the stuff to start this project. Valve Covers, Looms, Wires etc. What about the air cleaner? I have the original L-82 set up on it now.I guess its like ram air or something with the two accordion looking ducts and plastic stuff out to the core support.With this you can hardly see my engine. I want a nice clean no crap look. Will it hurt to take all this original breather stuff off and go with a simple cleaner? Ron.
Assuming the original breather unit is complete, it does have a heat stove to warm the air during the winter, to aid cold starting.
On the other hand, I've started my Shark in single-digit temperatures, with no major difficulty.
The "cold air" effect is marginal, in my opinion, when compared with the increase in reathing that you can get with a good air cleaner.
When I got my car, it had a 13-1/2" dia x 2-1/2" tall chrome-lid air cleaner. It's a bit scuffed up, so I'll probably replace it eventually, but it's pretty decent.
I'd rather have that, and actually be able to get at the engine, than have the huge factory system crouching over the entire engine :)
One thing to watch is the length of the air cleaner stud. The previous owner of mine put in a stud that was really too long, by about 1/2". It chewed a hole in the under-hood insulation (but didn't actually hit the hood), and just looked ugly. I finally had time amidst my other projects to chop off that excess half inch, re-bevel the end on the grinder, and clean up the threads. Much nicer, now - it is even with the top of the wing nut, when tightened down.
I can take some pictures, if you'd like. You'll have to bear with the mess, though - half my engine compartment is scattered around my garage, at the moment.
Joe
K&N Air Filter
You might think about getting a K&N filter. They breathe a lot better, and look pretty cool! And they can be cleaned and reused, instead of thrown away when dirty. I think they even have a good warranty. Just a thought!
Bill
That's another good thing. When my current filter gets dirty, I'm replacing it with a K&N. A little more expensive, but you can clean them, so they pay for themselves, in the long run.
Joe
I left all my "smog" crap on.
A little paint here and there, and I think it turned out pretty good.
You can see it in the members photo gallery.
