Feltman
If I was to drop a valve (Exhaust Valve), would it sound like I have an exhaust leak? I have what appears to be coming frim the right rear Valve cover. I have replaced the heat riser valve, since I assumed that was where it is coming from. Did a visual on the manifold could not see or feel anything. The sound is more pronounced at idle, especially when you first put it in gear, plus the exhaust from the right side (where the sound is coming from is hotter than the left side). Thanks for being the middle mechanic
Any help would be great. I did install true dual exhaust from Mid America.
