i dont know what it is....the engine seems to run fine most of the time.
When i go for a longer trip , it runs bad when i give it the gas....hesitates , like the timing is off or a vacuum issue....would a leaky valve cover cause a leak in the vacuum?
I have what seems to be a leak in the valve cover , but only when it gets hot.
I bought these to replace the big block style that was on it when i got it...i had this leak issue last season and thought i got it fixed with a new gasket....looks like i didnt...im going to get a new set of covers , cast aluminum...hope this will be the fix for the leak....i spoke with c4c5specialest at the cruisefest seminar , and would hope he see's this to help jog my memory as to how i was to test for a leak in the vacuum.
Does it sound like im on track ?
or do you think it could be a diffrent issue?
have new manifold gaskets and a brand new edelbrock performer carb 600 and a performer intake...i have the fuel regulated at 6 lbs.
Any thoughts?
Chas
Any thoughts?
Chas
