A
aaron1
When engine is cold it has a slight engine miss. However after vette is driven for an hour the miss i more noticeable as the engine is now jumping around.
I believe this to be an ignition problem. would a primary ignition issue be the cause? It has new wires and ac delco plugs and new cap and rotor.
I will check the plugs and wires.
Thanks for everyones help.
aaron1
aaron1
