S
sbushwhacker
I originally posted a thread on a ticking noise on my y2k coupe, this was barely noticeable. I thought it was a lazy lifter or a fuel noisy injector, it was minor but irritating. Since then I had driven about 10k m., when on a trip around the block the noise got much louder and constant. I was sure it was in the valve train now. Not knowing what to do I spoke with the vette guy ay the local chevy dealer. After talking to him I decided to look into it myself, and after removing the valve cover I saw nothing obvious. I then looked closer and noticed the rear most pushrod hole in the head to be oblong while the others were round. When I loosened the rocker arm I found the pushrod to be broken in two and bent. Again I spoke to the vette guy and he was not too encouraging. I then bought a new rocker arm and pushrod, then I drained and replaced the mobil-1 and changed the parts. Good news is the engine seems to be fine, the bad news is that the ticking is still there ever so lightly. Note! I bought this car used with 4k m. and I have NEVER over reved the motor or missed a shift, so now what???:confused
