S
sothpaw
Hi all,
On the way home from an autocross, going up I-95 in heavy traffic in the rain, my newly
moded vette ran in to some serious engine problems. Basically, the engine speed would
become more and more eratic and I could not keep it in gear as it was bucking the car.
In other words, it was running rough, both at idle and under load, at any rpm. And it got
rougher until the engine stopped (well, I had a hard time pulling over in traffic the first time).
other facts:
1. Coolant and oil temps normal. (water pump should be good and is 1 month old)
2. Weather was rainy and 100% humidity, and I was following in traffic so there could
have been a little water spray on the car. But I did not hit a huge puddle that I saw.
3. Only code in CCM or ECM was CCM H74, which I am pretty sure is totally unrelated and I
have seen that before.
4. When I stopped, and waited, the car would run for a while and then it would happen again.
It seemed like the longer I waited, the longer it would run. At the end, my patience was thin,
and it didn't last 2 minutes, but then, I had only waited 5 or so.
My guesses:
Optispark: ? I just replaced one month ago, brand new, 1996 style, not refurbished. Still, this
seems like a classic Opti failure to me.
? I did have the car jumped last week when I drained the battery accidently.
? I have an Ed wright chip, Comp cam, new heads, timing chain, opti, and waterpump.
? Fuel pump? It started great every time I started it after waiting.
Thanks for any help!!
other facts:
My guesses:
