M
Mungo 75
My 75 has most of the smog stuff removed, only have egr valve, vacuum advance, fitting on manifold for headlights, 2 outlet sensor on thermostat
housing, and another 2 outlet fitting on front passenger side manifold. I
was replacing hoses and upon checking the ones removed, found a screw
plugging one of the hoses but it was an inch into the hose and was attached
to a fitting but I don't know which one. Anybody know exactly what is needed
or what is not. Appreciate any help you can give. Thanks
