silver00v6camaro
ok im going crazy depending on what path i should take. As we all know i got the bad end of the deal on my motor build using crap somg heads and rpm cam
. Well I was planning on using some vortec heads upgraded for more lift with a comp xe262 cam and an air gap intake. Well I have been pondering the idea of a crate motor. To do the top end pakage im right at about 2500 bucks give or take a few this is using the stock bottom end with 4 valve reilfe pistons that have a lot of carbon build up for a rebuilt motor with less than 1000 miles on it. I fiqure for a few bucks more i can get a motor i know was built well and comes with a 2 year 12,000 mile warranty. Well I am looking at this crate motor from Derebery Performance. Here are the specs
350 ci 400 HP 430 TQ $2,995.00
-Balanced Dynamically
-9.5:1 Compression
-6000 RPM Limiter
-Hyperutectic Coated Pistons
-Hyd, Roller Camshaft 218/228 @.050 with .502/.502 lift
-Vortec Hand Ported Cylinder Heads
-Dual Plane Air Gap Intake Manifold
Idle
link to website http://www.dpmpower.us/smallblock.htm third one on the page.
So my thing is would you go for the crate motor or just do the top end and cam swap on my current motor that was built by bubba.
Thanks in advance for the help.
-9.5:1 Compression
-6000 RPM Limiter
Idle
