Help! EQR Temperature Sensor
Craig Herrick
New member
Huntingtown, Md.
1988 Silver Coupe
I need to replace the EQR Temperature Sensor on my '88. GM no longer produces this part and I can't find it. Someone told me that I may be able to buy the part for a newer model and improvise. Does anyone have any suggestions ?
:welcome
I'm not familiar with an EQR Temp sensor, sorry.
I think you meant EGR temp sensor. When I replaced mine on my 1988, it stated years 1985-1989 on the instructions. I purchased it at Mid-America. You may want to check if they still have any inventory on this discountined part.
Welcome to the CAC......Hope this helps. :thumb
Found this on google...statRacing.com - 24/7 Auto Parts Warehouse
statRacing is your Aftermarket and OEM Auto Parts Warehouse
OEM EGR Valve
Part Number: B7010-148235
Availability: In Stock (1 available)
Years: 86 - 91
$66.05
EGR Valve Original Equipment
OEM EGR Valve
That would be the valve itself;
he is after the temp switch that goes in the crossover pipe from exh manifold to intake.
I'm not familiar with an EGR Temp sensor,
If you are in fact referencing the EGR Temp Sensor, we should probably edit your thread title.
