keithcop
New member
- Joined
- Sep 5, 2013
- Messages
- 2
- Location
- Canada
- Corvette
- 1963 Split Window Jet Stream Blue, 2007 Z06 Yellow
Hello Everyone!
I am new to forums, so I will do the best I can!
I have a new to me 2007 Z06. It is a fixer upper! I am having issues finding/repairing the electronic suspension control module. I have a Tech 2 and it will not communicate with this module. I am new to the Tech 2...
I will deliver some back ground info so you all have as much info as I have. Most is not relevant to this specific issue but will give you an idea of the attention to detail the car has had in the past. It had an engine fire which was very light. Damage was to right outer carbon fibre fender, inner fender, hood and ECM wiring harness. It has a set of West coast Cylider heads on it and seems to have a cam swap. I have hooked up HPtuners and it deffinately needs to be programmed. It appears to have the original software in it. I have repaired all the wiring I found damaged and it runs ok at idle and wicked any where over 2300rpm. I will tune it up later. Is not running too lean or rich so no big deal for now?!? Chassis looks like it has been dropped out of car for engine work. Z06 has 14000 miles on it!
My question is: Does the 2007 Z06 have an ESC module? Where is it? It is not beside the ECM as shown in GM SI on my car. Nor is the wiring. It could have been removed due to fire. If so where does the harness break out to the ESC. The car does not have the sport/race button on the consule.
Any help would be greatly appreciated!!!
