kpic
- Joined
- Mar 29, 2014
- Messages
- 2,292
- Location
- Columbus, NC/NE Georgia
- Corvette
- 1997 boosted silver coupe
Gosh is this still continuing?
To get away from the internet, one needs to use this search: Scholarly articles for 10% ethanol gasoline and phase separation
The articles are written by techies and Ph.d types. In the articles, they discuss everything from how water gets into the pure gas to it's end affects on engines.
These are technical papers, not the usual stuff to read. Personally as I don't need to pass a course rather than read all of the above, I'll take their word for it. Doubters, feel free to embark on the most boring reading of their life.
MTBE
An Error Occurred Setting Your User Cookie
MTBE is does not phase separate; however, it can pollute ground water so it is a no-no
Fuel Phase Separation in Ethanol Blended Gasoline's
Courtesy of Scott Irwin
Did you know? In a 10% Ethanol Blend, it takes as little as 18 gallons of water in a 6,000 gallon tanks to cause Phase Separation. In a 2% blend it takes only 3.6 gallons to cause Phase Separation
What is "phase separation", and how do I deal with it?
If significant amounts of water are present in a fuel tank with gasoline that contains ethanol, the water will be drawn into the fuel until the saturation point is reached for the three-component mixture of water + gasoline + ethanol. Beyond this level of water, phase separation could cause most of the ethanol and water to separate from the bulk fuel and drop to the bottom of the tank, leaving gasoline with a significantly reduced level of ethanol in the upper phase. If the lower phase of water and ethanol is large enough to reach the fuel inlet, it could be pumped directly to the engine and cause significant problems. Even if the ethanol water phase at the bottom of the tank is not drawn into the fuel inlet, the reduced ethanol level of the fuel reduces the octane rating by as much as 3 octane numbers, which could result in engine problems.
Well-Worth Products, Inc.: Articles - Fuel Phase Separation in Ethanol Blended Gasoline's
Ethanol-Water Phase Separation White Paper
Samir Jain
Background
The use of ethanol as a fuel in the United States has significantly increased over the past decade.
Today, greater than 80% of all retail gas stations in the US blend gasoline with up to 10%
ethanol (E10). Ethanol is a renewable fuel, and has been highlighted by the national Renewable
Fuels Standard as a primary method of achieving the renewable fuels goal. Ethanol is also an
octane booster, and E10 fuels rely on the ethanol content to achieve octane levels.
Water Intrusion
Fuel is typically stored in underground storage tanks (UST) and it is common for water to find its
way into these tanks. Prior to the use of ethanol, water entering the tank would drop through the
fuel and find its way to the bottom of the tank were it could be detected and removed before it
would be picked up by the pumping system and delivered into a vehicle. Pure water is heavier, or
denser, than gasoline-based fuels. The following table shows the density of various fluids at
15°C (59°F):
Ethanol is a hydrophilic compound, which means it naturally attracts water. Therefore when
water enters a tank containing an ethanol blended fuel, the water will eventually be absorbed by
the ethanol. The amount of water that is absorbed in the fuel versus falling to the bottom is a
function of the rate of water flow into the tank along with the amount of mixing that occurs. Full
absorption usually requires some kind of mixing such as that provided during a fuel delivery to a
UST. Table 2 highlights many common reasons for water intrusion in an underground storage
tank, and the rate at which water flows into a tank.
http://nationalpetroleum.net/Ethanol-Water-Phase-Separation-facts.pdf
Journal of Petroleum Technology and Alternative Fuels Vol. 2(3), pp. 35-44, March 2011
Available online at Journal of Petroleum Technology and Alternative Fuels
©2011 Academic Journal
Full Length Research Paper
Physico-chemical properties of bio-ethanol/gasoline
blends and the qualitative effect of different blends on
gasoline quality and engine performance
Tangka J. K.1*, Berinyuy J. E.2, Tekounegnin3 and Okale A. N.3
Physico-chemical and operational properties of various gasoline bio-ethanol blends were evaluated.
Bio-ethanol was obtained through distillation from maize (Zea mays), sugar cane (Saccharum L), raffia
(Raffia vinefera) wine, and palm wine and then purified using a rotavapor. Engine trails involved
combinations of various ratios of gasoline/bio-ethanol as fuel in a small unmodified gasoline engine
connected to a dynamometer. The vapour pressure, octane number, flash point, specific gravity, and
energy density of various compositions of the blends were evaluated. Sugar cane gave the highest
yield of alcohol 97.99 g per kg of produce while the lowest amount of alcohol of 10.5 ml per kg of
produce was obtained from palm wine. Engine power decreased from 0.400 kW with 100% gasoline as
fuel to 0.108 kW with a gasoline ethanol ratio of 1: 10. The octane number increased from 93 at E10 to
106 at E90. The energy density decreased from 33.180 MJ/l at E10 to 23.600 MJ/l at E90. Other physical
observations suggest that to successfully run a gasoline engine with bio ethanol/gasoline blends some
modifications would have to be done on the engine, including advancing of ignition timing, provision of
air tight fuel conduit network, and modification of piston heads to improve pre-combustion fuel
homogenisation.
MTBE
