- Joined
- Feb 8, 2004
- Messages
- 1,102
- Location
- Southeast, PA
- Corvette
- 2003 50th Annversary Red coupe, beautiful !
I have huge carbon build-up in the heads from the previous owner of my l-98 using nothing but cheap regular 87 and now I have an engine that won't start if the outside temps are below 50 degrees. The problem is the desist of the air/fuel mixture and it can't get around the carbon buildup and into the cylinder before the intake valve closes, the piston come up and the spark plug fires, but there's not enough fuel in the air/fuel mixture to start.
Is there anyway to decarbonize a cylinder heads intake ports without removing the cylinder heads or is the only remedy taking off the heads and sending them out to be cleaned and rebuilt ? I've run it on only ExxonMobil supreme 93 octane and I've added about 12 to 15 bottles of Chevron/Techron cleaner to a tank of fresh gas but it hasn't reduced the build-ups ? :ugh
