LJ Hawkeye
Background:
2001 Corvette coupe ordered from the factory through a local dealer with delivery in November, 2000. Almost since taking possession the car appeared to be using oil - roughly 1 qt. every 1,500 to 2,000 miles. I wasn’t that concerned, since I assumed that was typical for that model (my previous vette was an '87). I mentioned it several times to the dealer, but was always told that was normal. At 27,320, dealer did an oil change and began an oil consumption test. I monitored the consumption, with the following results:
• 28,332 (1,012 miles) - 1 qt
• 29,373 (1,041 miles) - 1 qt
• 30,598 (1,225 miles) - 1 qt
• 31,371 (776 miles) - 2 qts
Each time I added oil, I was told that the consumption was "normal.” Since then, I have continued to monitor the consumption, but haven't kept track. Eventually I advised dealer who suggested another oil consumption test. I was not told to bring the car in after an oil change to have the drain plug sealed, just to change the oil and filter and monitor the usage.
• 37,652 - oil changed with new filter
• 38,459 (807 miles) - 1 qt
• 38,865 (406 miles) - 2 qts
• 39,200 (741 miles) - 1 qt
• 40,259 (1,059 miles) - 1 qt
• 41,205 (946 miles) - 2 qts
• 42,325 (1,120 miles) - 1 qt
• 43,209 (884 miles) - 2 qts
Service rep advised that another oil consumption test needed to be done. None of the previous oil consumption could be documented, since they hadn't sealed the drain plug (now he tells me).
• 43,923 - oil change done and oil consumption test begun by having dealer seal drain plug.
• 45,075 (1,152 miles) - 1+ qts
Called service rep and he advised to bring in for confirmation and oil replacement. Service rep checked oil level, added 1 quart and said he would check with the extended warranty company.
Service rep called to tell me the extended warranty company felt the oil consumption was “within normal limits.” They further explained that (I’m paraphrasing), if I wanted to, dealer could explore further by opening up the engine for a physical inspection. They would only pay for that inspection if actual damage was found to the internal engine parts that would be covered under the extended warranty. Service rep advised that the inspection process could cost as much as $2,000 to $3,000, which I would have to pay for. I decided to continue monitoring the oil consumption. Continued to check the oil on a weekly basis.
• 46,278 (1,150 miles) 1+ qts
Called service rep on to advise. He said he would add this info to the record. He advised to add a quart and continue to monitor. No need to bring the car in for confirmation.
• 46,829 (551 miles) 1 qt.
Called service rep to advise. He said he would add this latest information to his records and to call the next time I showed a quart low. At that time he would check with the extended warranty company again.
• 48,053 current mileage (1,224 miles) - 1 qt
I apologize for the lengthy detailed history, but I wanted everyone to have all the information. My question is this: Does anyone have any information that I could use to pass on to the dealer and ultimately the extended warranty company to show that something is wrong and warrants further diagnostics, but not at my expense?
Thanks in advance.
LJ Hawkeye
Thanks in advance.
LJ Hawkeye
