exhaust question?
  • Thread starter Thread starter lg78VETTE
L
lg78VETTE
I am putting on azo6 exhaust on my 98.The question i have is are there gaskets between the h pipe and mufflers?I have not taken the originals off yet.
Yes there is.
If you remove the gaskets carefully you may be able to use them again if you like. I did that when I installed Corsa Indys on my car and have not had a problem.
:nono
Always, always replace gaskets when changing out or removing anything with the gasket. They are cheap, in relative proportion to the parts being removed, and its never worth the savings to merely re-use the old gasket.
Silver 98,
I do understand about reusing gaskets. However, it is likely impossible to find what I need here in Italy.
If they were engine gaskets I would not even have tried.
We used silicon on mine and it has not been a problem.
orange silicone will work fine:beer
