F/S 1985 L98 Corvette...details inside
tntcorvette
Chicago, Il
Im selling my 1985 L98 corvette. Here is the scoop on the car.
New paint
new tires & zr1 wheels
TPIS cold air kit
Transmission cooler
Holley 58mm throttle body
TPIS Miniram II
Ford SVO 24lb injectors
MSD coil, Accel cap and rotor
Ported AFR 190 heads
Comp Cams hyd. roller 224/230 (.53x/.54x with 1.5 rocker) on 112 lsa
Comp Cams valve train with 1.6 rockers arms, retro fit hyd. roller lifters, pushrods, springs, locks, retainers, etc
10.0:1 357 sbc with lightweight forged JE Pistons
Stock crank and rods
ARP bolts through out the motor
stock syle oil pump
Hooker 2149 headers
BPP Air pump eliminator kit
B&B 3" cat back
3" high flow bullet cat. converters
Vette Brakes & Products suspension
ZR1 front brake kit 13" w/s.s. lines up front
OEM rear 12" rear brakes withe newer pads/rotors
3.07 dana 36 rear
Alpine tape deck w/6 disc changer (crazy x girlfriend has the cartdridge)
tinted windows
GM 7730 speed density ecm with ed wright chip
New brake booster and master cylinder
K&N air filter
Engine professionally built by http://www.fastimesmotorworks.com and has under 1000 miles on the motor. It does not burn one drop of oil and runs very strong. I can spin the tires on this car all the way through 1st gear w/o a problem.
The transmission needs servicing and although the mail order chip is pretty good it could use some time on the dyno to fine tune the cars potential.
Car is sitting on jackstands in my garage and has been there for about 8 months because the transmission needs servicing but has been started on a regular basis. Also the headers will proabbly need to be recoated in a couple of years as there are some oil stains on them from oil changes.
I also have a set of "tall" CHEVROLET valve covers and the windshield wiper motor has been removed and needs to be replaced with either a smaller one or can be put back on with the stock style valve covers (which I do not have).
I am not willing to take my time are part the car out so I am prepared to sell this car at a discount.
please email any offers to kej1974@yahoo.com
if not the car will be on ebay in a couple of weeks.
