factory alarm
Raidervette
Oh.
74 Coupe, Bright Yellow
I'm a little lost. Just replaced trany lock out cable thought that was my problem but my alarm still blast when I turn it on. Any ideas?
74-4speed
I can shut it off with the key, but I'm tryoing to get it to work properly. I believe the wiring is still good,I'm not sure about the thing on the side of the transmission that the two wires run into.
Do a search about alarms. There have been some posts. I have no idea of what the transmission wiring is. Your's may have been improved over the early alarms, which just rang a horn until the battery went dead.
i took it out...
didnt take much to do.....and i like the key fob switch to set it instead of the old key...i have all the parts....there yours if you need any of it pal...chas.:bu
