M
Muddy
I went and put my vett (1992 manual transmission) through the state inspection today and it failed :cry. I was advised to take the performance chip out and put the factory one back in.
Here is the question; on the performance chip assembly (Hypertech) there is a blue colored holder that has some ICs in it, would I be correct in presuming this is the original EPROM for the car and if I reinstalled it, the car would return to the factory default settings? The blue unit has DELCO BAFL 3867on it.
I also noticed that the, I want to say, white wire (but it is discolored) on the Gray connector (pin 9) on the ECM unit had been cut, would I have to reconnect this wire as well? :confused
Any info on this is very much appreciated.
Cheers
Muddy
Cheers
Muddy
