delray56
I have a Roman Red 62 purchased 18 months ago. I freshened up my 327 this past winter with a new L79 cam, cast iron rings, and new bearings and rod bolts. The bores were done previously at .040 over and the high compression pistons looked like new. It has double hump heads and the valves were ground with this project. The engine burned no oil previously but the compression was on the weak side, and since I was installing a Tremec 600 this winter, it made sense to freshen up the 327.
My machine shop said the bores were in good shape and all that was needed was honing. The new rings are cast iron and were installed per the instructions with the marks on the top side. Ring gaps were to spec.
It should be noted that the engine went through two cam breakin cycles before the car hit the road. Due to an ordering screw-up, the first cam was completely wrong for the engine so it was removed after only 2 miles of driving. I used Royal Purple Break-in Oil and did both break-ins per Erson's instructions - 20 minutes at 2000 rpm. I vary the engine rpm on the road and shift between 4th and 5th often in order to put some varying load on the engine. I haven't babied it, but I need to take it a bit easy because of the new Tremec.
After 750 miles of all types of driving this summer I have burned 2 quarts of oil, including 1 quart in the last 200 miles. All of the spark plugs are wet with oil, and a compression check shows an extremely disappointing 95 - 110 psi range. Surprisingly the engine runs great. This is my first engine rebuild in the "low zinc oil" era so I'm completely frustrated with such poor results. Royal Purple recommends leaving the break-in oil in for 1500 miles or so, but I'm desperate to try anything so I'm draining the Royal Purple and going with 10W-30 dinosaur oil. I realize it's probably too late to save this engine as-is, so I plan to buy a ZZ4 short block this coming winter and start over, using my L79 cam and double hump heads.
I'm so frustrated right now because I have reviewed my rebuild notes and can't see where I did anything wrong. Has anyone out there had such an utter failure with rings lately? I'm so gun-shy now that I don't want to try another ring job on this engine. As I mentioned earlier, these same pistons and bores burned no oil last year.
Did the two consecutive cam break-ins affect the initial ring seating? I changed oil between break-ins but used Royal Purple Break-in oil for both. My machine shop guy suggested that I wind the engine up in 2nd gear and let the compression drag the car back down. I did this 10 times. The oil usage is just getting worse. There is not a drop of oil on the ground or anywhere on the undercarriage.
