toobroketoretire
Banned
I have made numerous attempts to check my fuel mileage on long trips and every one of them was screwed up because of some goofy problem:
1. On a trip to the coast and back my transmission's t/c clutch kept rapidly disengaging and reengaging which made a horrendous vibration and caused me to drive most of the way in 3rd gear.
2. On a trip to the coast and back I found my trip meter was adding an additional 5 miles for every 10 miles driven. As I didn't write my odometer reading down at the start I had no idea how far I had actually driven.
3. On a trip to the coast and back I found my vacuum advance had failed so my fuel mileage was much less than usual.
4. On a trip to Los Angeles and back I had 4 spark plugs foul (on the way back) which really screwed up my fuel mileage.
5. On my last trip to the coast and back my #2 cylinder quit firing so once again my mileage check was screwed up.
On Tuesday the 16th I'll be going to Santa Barbara and back (about 500 miles) and hopefully nothing will go wrong this time. I am hoping to get 16 mpg which would double the 8 mpg it started off with when it had the marine cam and TH400 with 3.08 gears. As usual I'll be making the trip with my 24/20 psi tires and .035" plug gaps to get the maximum mileage possible but this will be the first trip with my Ram Air and leaner #70 primary jets.
