toobroketoretire
Banned
Back in the early 60s when fan clutches first appeared people immediately hated them because they didn't understand how they worked (the fear of the unknown). So along came the solid aluminum "fan clutch eliminators" that replaced the fan clutch. In theory it sounded like a good idea BUT the 5 and 7 blade G.M. fans were out-of-balance ON PURPOSE to prevent excessive fan speeds. So when a fan clutch eliminator was used the vibration caused by the out-of-balance fan was so horrific the water pumps came loose. If you doubt the fans were out-of-balance take a good look at a 5 blade G.M. fan and notice how 3 blades are on one side and two on the other side. The 7 blade fans are the same way but the out-of-balance isn't nearly as obvious because of the 2 additional blades. The out-of-balance fan combined with the fluid coupling of the fan clutch prevents the fan from unnecessary high speeds.
Fan clutch eliminators are still sold but they are only intended for balanced fans and not the 5 and 7 blade G.M. fans used from the 60's into the early 80's.
ad
