As this car is a 95, let me clear-up some misconceptions. First, 95s have no "senders" which control fan ons. The fan-ons are commanded by the engine computer. If you want fan-on temp to be lower and you want it to work automaticly (by far the best way---those using manual switches are just fooling themselves---yes the engine runs cooler at times, but the temperature control is inconsistent), the only way is to change the ECM calibration.
You can have someone reprogram your ECM or you can do it yourself with a device such as the Hyper Tech Power Programmer or software such as LT1 Edit.
Keep in mind that just lowering the fan-ons may not be all you need to do. If the cooling system is not maintained properly, it may not be able to sustain a lower temperature in traffic and, on really hot days, even if it's in perfect shape, it won't be able to sustain a significantly lower temp.
