Zixxer
Ok, I've searched the forums high and low and read just about every post on the subject but I'm still not clear on something:
I have two fans, primary (left side) and secondary (right side)....is the primary fan suppose to kick on at given temperature? or is the primary set to a lower degree and should heat build up the secondary fan kicks on? I know if I turn the A/C on both fans are working but I have yet to understand when the primary should kick on v. the secondary.
