HVAC B1000, B0248 and B3748
IPC    B2861, U1041, I1088, U1193, U1153, U1024,U1054, U1017 and U1301
Seems these are "communication faults" the dealer does not have a lot of experience working on Corvettes and I did not buy the care from them so any ideas or feed-back will be appreciated.
The dealer personel are friendly and seem to be trying but so far have not found anything.
Sorry, Don't have a clue as to what model Corvette you have, year of production or anything else. The following are some codes I looked up for the C5 Vette.
Some of your codes are NOT in the C5 DTC listings.  It would be most helpful for anyone trying to help you to give as much information to them as possible.
Since you didn't say and because I didn't find several of your codes in the C5 DTC list, I'm guessing you have a C6? Maybe????
All "B" prefix codes are issued by the BCM.
The "U" prefix codes are communication error codes on the CAN bus between all the computers on the car.
B1000
B0248 Air Flow Control Circuit 3
B3748
IPC B2861
U1017
U1024
U1041
U1054
U1153 Loss of Communications with HVAC
U1193
U1301 Class 2 Circuit Shorted To Battery
I'll take a SWAG at it with the very small amount of information given......
The battery is mounted over one of the computers, directly above it. There have been cases where the battery leaked electrolyte onto that computer, wire harness and connectors. This has in some cases causes wreaked havoc with the functioning of the communication between control modules on the Corvette.
Maybe have your service professionals take a look there for trouble.
U1301 indicates a problem with a wire harness or connector with the Class 2 Buss Communication line shorted to the battery.
If the car has been in an accident this could have occurred. If the harness has been damaged by battery acid it also could be the cause.
Think I would look for that U1301 fault, fix that and then check codes again.  Splice Pack SP205 or SP208 may be involved.  There is a procedure in the FSM describing how to use the TECH II to check this.
There's just not enough background information to go much farther on.
Good luck with it.
