Faux or functional?
  • Thread starter Thread starter VAmagred01
V
VAmagred01
Side scoops (the ones in front of the doors). What do they do?
That's what I thought. They should have run ducts from the engine compartment to those vents to extract hot air.
Thanks for the info,
Kenny
They do extract hot air - just not very much of it as there's too much stuff between them and the air flow under the hood.
Thanks, Tuna. You know, there are so many things [small] GM could have done to enhance the performance of the Corvette.....but I guess they needed to leave a little room for aftermarket upgrades.
And they also vent heat from the most important part of the electronics.
True.... I had not thought of that.
I think if they vented the engine compartment through there, every time you ran through a puddle of water or an errant sprinkler system that was spraying the street, you’d shoot dirty old road water down the sides of the car.
