Y
yooperod
A buddie of mine purchased a 78 that needs The fender & door replaced & some glass repair.
I'm familiar with working on C-2s.But I see that some bonding adhesives and resin are listed to use on 73-82 smc panel.
The local paint store says this only applies to the '84 and newer cars. Whats the scoop on this?
What products should be used?
Is 73-82 glass different than the older cars?
We picked up a used fender(upper and lower)
The plan so far is to cut the fender 1/2 way
thru the headlight opening,break it loose from the bond on the header bar,
Fit new fender and bond it on.
then grind down the seam to the bonding and fill with cloth and resin.
We got to get this project in gear soon springs coming.
ALL advice is appreciated.
thx. rod
thx. rod
