Darksaga
It's a 6 speed, LT1.
I had a few questions I wanted to clear up.
Question #1:
I notice after driving down the highway for a while the CEL will come on then go off after several minutes. That's the only time it will come on and I can't figure out why.
Question #2:
I notice at idle the exhaust sound is off. If I can post a video I will but it just seems like a slight miss or infrequent exhaust note.
The idle RPM is fine though, doesn't fluctuate unde ror over 800 or so RPM.
Question #3
When I shift at around 2,500-3,500 rpm or above in 1st, and 2nd gears (The lower gears) I notice a quick popple/crackle sound from the exhaust, it's fairly loud to what I'm used to in other manual cars.
Question #4:
How many O2 sensors are on this car and which are the ones that usually need replaced? I bought a couple NTK upstream sensors since they were reasonable and made by NGK.
Question #5:
How do you reset codes?
Question #1:
Question #2:
Question #3
Question #4:
Question #5:
