qblue90
- Joined
- Jun 2, 2008
- Messages
- 43
- Location
- S.E. Michigan
- Corvette
- 1990 Quasar Blue 6 spd,Z51,FX3,J55,GT7
Okay... I did'nt use the right tools and I did'nt pay enough attention to what I was doing and I caused damage. It's relatively minor, but I am still upset with myself and I ask if anyone knows what I should use to fix this...
I needed to jack up my 90. I placed my 3 ton floor jack under the jack location behind the LF tire. The jack has the standard round metal pad on it. I began to raise the vehicle. Luckily, I noticed something was wrong almost quick enough... I had put the jack a bit too far under the vehicle and the round pad was biting into the left front corner of my fiberglass floor pan. It cut a nice gash in it the same width and just as deep. It is not through that I can tell and its not cracked or broken. Just cut.
How can I repair this so it will not get any worse? I imagine that I'd just use a fiberglass repair kit of some kind, but what exactly? Don't want to do more harm.
See what trying to rush a job will get you?
I appreciate any help as always...
