93Rubie
I've been searching for a set of Z07 springs and bars for my 93 FX3 coupe. I've found them, but the car they are coming off of has 220K miles on it. The LT1 finally spun a bearing I am told. I know that GM tested the springs quite extensively and my understanding is that they are practically not able to be worn out unlike a steel spring. So both the front and rear springs (pending no delamination/damage) should be the correct rates for many miles to come and under use. Agree or disagree, why?
The front sway bar is 30mm on the Z07 package and I can get one of these to. Now they are steel but are not under the loads that a spring is. So pending no damage, I would think it to would be good for many more miles/use. Agree or disagree, why?
One final question, how critical is the HD lower bushing in converting a non-Z07 car to a Z07 car? I would think minimal at best.
Also, would you consider running the big 30mm bar on my stock FX3 spring/shock/rear bar (24mm-same as Z07) without the stiffer springs? I would think this would cause more under-steer not less, then again with less body roll more weight would stay on the outside of the car in the turn??? Just entertaining a thought on this one.
