grumpyvette
I got asked about how to figure engine displacement and I figured there may be a need to find other info so....
get out your calculator
the formula is BORE x BORE x stroke X NUMBER OF CYLINDERS x .7854= displacement
DISPLACEMENT is the voluum of the cylinder formed by the travel the pistons displace between top dead center and bottom dead center times the number of cylinders, example if an engine had a 4" dia. piston and it moved down 3.48" between its upper and lower extremes that cylinder would displace, aproximately 43.73 cubic inches, eight of those in a sbc 350 would be the displacement 43.73 x 8 =349.8 or rounded to the nearest inch,to 350
EXAMPLE
4.030" bore times 4.030 " bore times 3.75" stroke times eight cylinders times .7854 = 382.7 OR a 383 sbc
heres other usefull calculators
http://www.csgnetwork.com/compcalc.html
http://www.angelfire.com/fl/procrastination/motor.html
http://www.4racecars.com/calculators/displacement_calculator.html
http://hotrodworks.net/hotrodmath/hotrodmath.html
http://www.diamondracing.net/cocalc.htm
http://users.erols.com/srweiss/index.html#jcalc
http://users.erols.com/dmapes/GEARCLC.HTM
http://www.doverusa.com/compression-height-calculator.htm
http://kb-silvolite.com/calc.php
http://www.bgsoflex.com/crchange.html
http://victorylibrary.com/mopar/intake-tech-c.htm
http://www.rbracing-rsr.com/runnertorquecalc.html
http://www.bgsoflex.com/intakeln.html
http://www.me.psu.edu/me415/SPRING02/intake/intake.html
http://headerdesign.com/extras/engine.asp#Intake_Manifolds
http://www.team-integra.net/sections/articles/showArticle.asp?ArticleID=466
http://turbonation.com/intake.htm
http://cochise.uia.net/pkelley2/DynamicCR.html
http://victorylibrary.com/mopar/header-tech-c.htm
EXAMPLE
