starbuck
So I've not owned a car with an auto transmission since 1990. My 1974 MGB has the standard 4-speed and was my daily driver for 10 years.
Well I have a 1995 Corvette coupe with the auto OD tranny (yes, I know, auto in a Vette..just not kosher for many)
But, after reading post on this forum for a few weeks now, I realized that I have never changed the auto fluid and filter in the thing! I bought it at 65k miles and it now has 145k miles on it. I've never even checked it until today (though I assume the dealership had the many times I brought it in for oil changes & lube or servicing that I didn't have the capablity or equipment to do myself)
I otherwise maintain the car very well but I just simply forgot that it has an auto tranny...sounds weird, I know, but out of sight, out of mind...
I've read that changing neglected auto tranny fluid and filter will often cause the tranny to fail completely. The story goes that the metal particles and gunk in the fluid actually helps hold a worn tranny together and changing it makes the tranny die.
The Transmission shifts fine, engages like it should and there is no problem with it.
The fluid looks absolutely perfect, isn't cloudy or dirty and it doesn't smell burned at all.
So what is the final say on this question?
Is it a wives' tale or is it reality?
Will changing old very old tranny fluid and filter cause a transmission failure or is it more of an urban legend. Mechanics I've talked to come down on this issue around 50-50.
