First review of the 3.54
81 Corvette
Toledo
1981 Pearl White
:D
What a difference. The engine revs up so much faster (23%) and smoother. Unfortually, its break in time, so I have to take it easy, but I like it so far. I did stomp it once from a stop in my parking lot at home, and it easily left some rubber on a slight incline, where as before, it might, if lucky, chirp the tires.
I keep very detailed gas records, so once i get thru a few tanks, I'll have mpg impact as well.
Before it seems to take forever to get going from a stop, now it feels alot more nibble.
I've got a gtech, (i know its not the track), but it will give some comparable times to see the improvement, which I'll post if anyone is interested.
What gears did you have before?
Are you still running the stock wheels and tires?
2.87 was the prior gear, stock rims, tires are kelly charges 225 70 r15
the cost ended up being close to 2K. labor was 800 for everything. parts included
precision ring and gear 210
bearing kit 130
vbp adjustable strut rods 120
side yokes 250
spindle support 106
some bushings 30
u joints, wheel bearings for the spindle support replacement (free labor on the replacement since they broke the support)
new carrier (not on the invoice)
they broke the spindle support trying to remove the lower shock mount. they ate some labor on that for me.
be careful if you have to remove the strut rods....this is what can happen if you are not careful.....this is the rear spindle support....the shock mount was stuck in there pretty good, and the snapped off the one side beating the mount out. the break was thru 1/4in by 1in of cast steel
Follow up....
Second drive
Took off and went to Barnes and Nobles for some coffee, and of course to play a little with the car.
I'm really liking the new gears. Its feels soooo much quicker off the line. It also feels like the engine is hardly having to work to get going. Before, with the 2.87, it seemed the motor had to labor a bit to get it up to speed. Now, its hits third gear, and i hardly notice teh 1-2 or 2-3 shift.
The only downside so far is I have only a vague idea of how fast I'm going. Gotta track down a new speedo gear, or at least put a thrid gear RPM=Speed chart on the rear view mirror :jester:
I'm glad I didn't go all the way to 3.73, then again, i sit here and say that without first had knowledge of what it would feel like, but I'm betting traction would be a major issue when i finally get a new motor. Time to start saving for a ZZ4 or ZZ383, and offset trailing arms
If you get that 383, you'd better save up for some rear tires as well! :L
Have you thought about going with bigger wheels and tires?
How long is the break in period?
i just got out of my break in...went from 3.08 to 3.55.....what an amazing diffrence!
3.08 was turning 2400 rpm @ 70 mph...
3.55 turns 3500 @ 70 mph...
had the speedo gear changed and the thing is with in 1 mph of the original...
dont push too hard till you get all those figure 8's done!...
(mine was about $2200 too...my core was toast...the ring bolts backed out and banged it up good.)
too fun to see the folks watching me do them in the parking lot...
"I'm ok...the turn signal has a short!";LOL
Good news pal...
Chas:beer
81 Corvette said:
Gotta track down a new speedo gear, or at least put a thrid gear RPM=Speed chart on the rear view mirror.
Assuming a 27" tire, 3.55:1 gears, and the lock-up feature of your THM350C is functioning properly, each 500 RPM (in 3rd gear/lock-up) is equal to 11.4 MPH.
Go to your local vinyl sign/decal shop, and purchase a piece of 'bulk' vinyl, and cut a piece of it to fit onto the glass lense of your tachometer, 'out-board' of the numbers signifying RPM.
Where the tach reads "10", put the number "23" (MPH); where it reads "15", put the number "35", where it reads "20", put "46", and so-on, for use until you get the correct speedo-gear.
Peel the vinyl decal away, using "Goo-Gone", or "Goof-Off" to remove any glue residue on the glass lense:
I did this on my Z28 when I went from 3.42s to 4.11s many-moons ago...
With any of the "ZZ"-series motors, traction with 3.73s or deeper would surely be a problem;
my lowly '82 Cross-Fire, with 3.73s, and a 700-R4 with 3.06:1 1st gear, can boil the 255/60R15 BFG TA Radials at-will, but once the tires catch, the L-83 bogs.....
:eyerole :mad :(
You ain't livin' until you've driven a Cross-Fire.....
:hb ;help :o
I have recorded every gallon of gas into my '82 since I bought it (May '00), but most of my driving is of the 'casual', 'out-for-the-afternoon/evening' variety, but on 2 occasions (once with 2.87s, the other with 3.73s), I had the '82 'out' on the open-road.
On a 230+ mile trek, with A/C blowing ice-cubes and the T-tops off at 75+ MPH on the Pa. Turnpike, I got 23.0 MPG (10 gallons even) with 2.87s:
on a 430+ mile jaunt, over back-roads and country-roads for better than half of it, I got 17.1 MPG with 3.73s.
On neither journey was I making a determined effort to get the best MPG, and in both instances, I was pleasantly surprised.
(A Cross-Fire does deliver good fuel-mileage, when operating correctly...)
Have the crap 2.8 in my th350 now,
will be reworked too 3.55 or I may drop in a th700r4
I had that one in my camaro and transam. The 3.73 gears
made a huge power launch difference. Also In OD the gas was 24MPG
cruising.
