First Time Trailer Buyer
Grizzly
Centerville, PA, USA
1967 Marlboro Maroon Coupe, 1992 White Convertible
Although my 67 is definitely not a trailer queen, I've given some thought to buying a trailer just to get it most of the way there. Would be nice to drive over to Carlisle or Bowling Green in comfort and then back it off the trailer. Also could secure it at night.
Anyone have any advice about what to look for? Should I look seriously for a closed one or don't I need to worry that much about damage. What kind of brakes? Solid deck or just ramps?
I just picked up a 2001 Ram, 5.9, factory towing package with about 8,000# capacity so I should have enough truck.
Thanks...............
Darn, you should have been looking when I was selling my Featherlite 20' enclosed trailer last year. It took me eight months to sell the thing, and I was practically giving it away, much as I'm now attempting to do with my truck. :hb
I loved my Featherlite! :upthumbs
Definitely get electric brakes. Also, I prefer the door ramp as opposed to individual ramps.
Having an enclosed trailer guarantees safety when you're in a motel room. ;)
I just bought an enclosed 20 ft trailer last year. If you want security get an enclosed trailer for obvious reasons. Also protects veh from road debris. Make sure the loading ramp and deck height is low enough to load your cars. Vette's have a long nose, clearance is an issue. Get one with brakes on both axles. Get one with 5200 lb axles each. Get 16" tires with at least 6 bolt hubs. Don't waste your time on a box trailer with 3500lb axles or 15" tires, you'll overload tires, axles, bearings, etc as soon as you load the car, never mind adding gear inside trailer. Do you want options? If so look to higher end trailers like TPD. If basic is what you need and cost is an issue, Pace American, Carson, etc are ok. Buy a GOOD brake controller like the teknosha prodigy or draw tite II. Cheaper is not the way to go with controllers. The first time you lock up all the trailer tires and flat spot you will have paid the cost of a good controller. Trailers with a dove tail rear make loading easier. If you're gonna go with an open trailer its easier to strap down on an open bottom trailer and it's lighter. A flat deck offers other uses besides hauling a car. Look for a dove tail rear again and good trailers will store the loading ramps from under the rear as opposed to the sides. If you have more questions pm or email me. By the way I had mine custom built, better than stock trailers, not quite as pricey as TPD or featherlite. But if weight is a concern you can't beat featherlite.
Thank you very much Jim (John? :confused), you said it better than I ever could. :CAC
Excellent post, Jim (?) - the axle capacity is a key issue - most lower-priced volume enclosed trailers don't have adequate GVW capacity to handle their own weight plus the weight of a 3300# car plus the other stuff you'll want to carry. Spend the money for excess capacity in axles, hubs, and tires. Other things to think about that make a difference (to me, anyway);
Full ramp door with extension flap.
One-piece roof panel (that's where they leak).
"E-Track" floor system for strap anchor location flexibility.
Beavertail floor (minimizes breakover angle so you can load any car without scrapes).
102" axles for minimal wheelhouse intrusion.
Access doors on both sides.
Underfloor compartment for spare tire/jack.
Roof vents.
12V/110V interior lighting & wiring.
Stone shield across the front.
12V winch with extension control - for easy one-person load/unload.
20' length - leaves room up front for cabinets, generator, compressor, tools.
Oh yeah, the winch. An indispensible item for those of us who travel alone.
Your description sounds just like my trailer John. A wonderful thing to have when you're traveling around the country. I even had room for my floor jack. :cool
Lots of things to think about and check, better make a list before I go looking.
Thanks for the advice folks...........................
Shop Around
Most of it's said here. I just bought a 7X12 for the Harley's and enclosed is the ONLY way to go. The car, motorcycle whatever is just as clean when you get where you're going as it was when you left not to mention your gear. Not to mention again it makes a great roling club house as seen by those that attended Cruisefest #1 in Auburn last year. Pay close attention to the axles, brakes distance between cross members, load range on the tires etc. There's a lot of places on the internet and quite a few in Pa. I've seen.
I didn't know you got one for the bike, Lou. Can you fit it inside the larger trailer too? :L
Ya Know.........
I'll have to try that!!!
A friend of mine from Australia is planning on getting a trailer and asked for some things to look for. In case this helps with your choice this is the message I sent him. Some might be additional information to what's already been posted while other suggestions are pretty consistent to what's already been said.
"We've had our current Renegade trailer for three years now and we use it for the long distance shows. It really comes in handy when going to shows during the winter as well as keeping the car safer for over-night stays on longer trips during the summer. While we drive the cars for local shows and cruise nights it's nice to do the prep work at your leisure in the garage and not on the showfield, at least for the long distance shows, and a trailer makes this doable.
Trailers come in many sizes but we've found that at least a 20' box will hold any Corvette and still give you enough room to hold other things you bring. Going much larger is usually unnecessary and just adds to the weight and makes parking more difficult. This trailer has a 24' box and is a "wide body" at 102" wide. It has a "beaver-tail" rear ramp door and a side access door. It's all aluminum including the frame and the exterior wall panels are assembled like an airplane with no screws and a one piece roof. It is quite a bit lighter than the steel framed Haulmark trailer we used to have and it's wedge shape in front really helps the stability. It also has a front closet which is great for storage. In the closet I installed wire bin shelves on one side and a panel on the other with hangers for the tow straps and other tools (jack handles, wheel chocks, etc.) which keeps things organized and handy.
Most of today's trailers come with a "beavertail" style pull down rear door which is best as it also functions as the drive up ramp. They also usually have a side entry door which is a real necessity. Some of the them also can have another drivers side door as an option which can allow you to open that door as well as your car's door to make it easier to get in and out. That was especially important on the narrower bodied trailers but the wide body units can reduce the need for that on many cars. I do find though that the C1, with it's thicker doors and especially with a hardtop in place, requires a little more space than the C2's. It's still doable though. Another thing to watch for is the height of the trailer inside wheel wells. They should be low enough to allow your car door to open over them. I have seen others with taller wheel wells where the car door will hit them and limit the space you have to get in and out of the car.
When looking for a trailer it's pretty much like looking for a new car or truck; lots of options to consider. It's amazing how little a unit comes with as standard equipment unless there is some sort of package on certain models. The spare tire, for example, would seem like a no-brainer but they aren't usually included. Neither is a hydraulic jack in case you do have a flat. Most trailers come with a crank style tongue jack. If your back is anything like mine something easier to use is nice. On this one I use a hydraulic type jack which works well. There are also electric units. You also have to make sure the trailer has sufficient capacity axles to carry the weight of the car as well as any gear. The ones on this unit are made by Dexter and have an "Easy Lube" design for greasing the axle bearings.
Some of the things to consider in the setup, and the more useful options, would be: spare tire, trailer jack, rear trailer stabilizer jacks (stabilizes the trailer if you are loading or unloading while unhooked), hydraulic or electric tongue jack, interior lights, front stone guard, break-away control, wheel chocks and locks, hitch lock, four ratchet type tie down straps (10,000 lb capacity each), winch, tire covers (during storage), trailer vents and good tow vehicle "camper style" mirrors. You might also want to consider getting a vinyl floor inside as it keeps things cleaner and it's much cheaper than adding it later. On this one I installed carpeting which also works real well. The carpeting has much less weight and is warmer especially when strapping the car down in the cold weather. You also need a good brake controller. I now use the Tekonsha Prodigy unit which works real well. Some vehicles, with the trailer towing option, are all set up for this and allow you to plug right into their pre-installed harness using the appropriate adaptor which simplifies the setup.
The other major consideration is the style and rating of the hitch, weight distribution setup and the sway control. The hitch should be a Class IV or V with a weight distributing setup. Adjusting the tension on the weight bars is also important as is setting the height at the hitch ball. The trailer should be very close to level when loaded with the car. Otherwise you can experience some sway. If anything, have the trailer hitch a tad (one inch) higher than the tow vehicle ball. You can get ball mounts which are adjustable to get the ball at the right height. On the sway control I use a "Dual Cam" style. Reese and Draw-Tite are two brands to look for.
Just to round out the practical things you might need, I also carry a pretty complete tool box, fire extinguisher, hand cleaner, paper towels and have mounted hooks for clothes. I have also found the winch to be real handy especially when moving a non-running car or chassis from place to place.
To tie the car down I like the ratchet type straps on all four corners. Some tie-down sets come with only two ratchets and two manually adjustable straps and you have to adjust the length of the front two straps which is a pain. The ratchet type lets you get the right tension easily on all four corners. It's best to mount the straps to the suspension which allows the car to move on it's suspension while not affecting the tension on the straps. My wife make pads to go over the straps to avoid any scratching which might happen where they go around the suspension. Straps which are rated at 10,000 capacity each are a good idea as it's not just the standing weight of the car but the weight in motion should you need to make a sudden stop. When loading the car I've found that getting in the right position is made much easier by fastening a tire chock to the floor in front of the drivers front tire. It helps get the car in the same place each time.
There are other trailer options like cabinets, workbenches, closets and finished walls/ceiling but they are not essential. Another real handy accessory is to install a camera on the back of the trailer. Our camper had one and I found one from Camping World for the truck. It has a TV monitor in the truck cab along with an intercom. It makes backing easier and it's also great to be able to see directly behind the trailer when going down the road especially when pulling out to pass or pulling back in. I also mounted a camera under the rear bumper of the truck which takes care of that blind spot when not towing the trailer."
Well, that's been our experience and I hope it helps to give you some different perspectives and things to consider. Best of luck with your search.
Rich Lagasse
Advice: Grizzly Buy This 26' Enclosed Pace
Advice ... sure do ... Buy My Trailer!
1998 26' Fully Enclosed Pace Tagalong w/ Electric brakes & dual axles. Designed for hauling 3300 lb race car & spares etc. plus some. Empty Trailer weight is 4500lbs. Seamless aluminum roof. Factory tie down points in floor but none elsewhere. Drive in-Drive Out. Full ramp door with flap, one side door near front, wired for both 12VDC & 110VAC, NO ac, NO heat, No tv. Cabinetry in front. Easily hauls late model stock circle track car with WIDE nose. I just adjusted the reels-cables on the ramp door and it's smooth as silk. Trailer in good condition and located 60 miles west of Myrtle Beach SC and about 5 miles off I-95. The Ram'll pull your vette in this trailer. Good condition. Clear SC title in my name. I don't need the money but I don't need the trailer either.$5750.
JACK:gap
Like to help you out Jack, but I always start to look early and do my homework. Need to get my son married off this summer and then I'll be able to take care of business.
Thanks................
No problem Grizzly ... lemme know when you're ready ... I haven't been advertizing so I might still have it.
JACK:gap
