AussieCorvetteNut
Hi Guys,
I am in the middle of planning for an engine rebuild.
I am upgrading my Crossfire Injection to a Tuned Port System (probably MAF at this stage).
I am also upgrading the heads to suit a retro-roller cam, lifters and roller rockers.
At this stage, I intend to re-use my matching numbers 2 bolt main block and the crank. If the block has issues, I will get another block, or if the crank has issues, then I am looking at a stroker crank.
I don't want to get into the debate of 2 bolt vs 4 bolt or stroking a 2 bolt block, the blocks in the early days were stroked with no problem, no such thing as a 4 bolt back in the day!
Ok, I am trying to research the best combos here and am keen on the Comp Cams retro roller cams:
# 12-464-8
# 12-465-8
# 12-466-8
# 12-467-8 and #12-468-8 look a little large!
Comp Cams have a complete kit that includes valve springs, retainers, cam, roller lifters, push rods etc.
I am also looking at a set of Edelbrock heads, 60995 (or core 60649 if I can get them).
These heads (60995) have roller cam hardware, but I am concerned with the valve springs.
Comp Cams supplies the ones they recommend in their K Kit, Edelbrock's springs are different...not sure.
Just need a little help and another set of eyes.
Tony
# 12-464-8
# 12-465-8
# 12-466-8
Tony
